Loop filter for HMC440 and HMC733 (sythentiser and VCO respectively)
The user inquired about the HMC440 application circuit, specifically the choice of opamp, biasing voltage, and LDO/regulator options. The support engineer confirmed that the LT6200 family is a suitable alternative to the THS4031, and a single +10V bias can be used instead of dual ±5V. For the LDO, the LT3045 is recommended, or direct connection with decoupling capacitors can be used.
Category: Datasheet/Specs
Product Number: HMC440; HMC733
I refer to the application circuit above from the datasheet of the HMC440 and will like to know the following:
1. I tried the several filters in ADsimPLL and the LT6200 seems to give the best phase noise performance. Is this a good choice of OpAmp or is a design as above limited to the THS4031 opamp as active filter?
2. Instead of the +/-5V for biasing the opamp, can I use a single bias of +10V and GND?
3. Any suggestions of a LDO or regulator that can be used with the opamp?
