Dear team,
Could I know the Moisture Sensitivity Level of LT5581?
I can't find this specification from datasheet.
Thank you.
Best & regards,
Josh
LT5581
Production
The LT5581 is a 10MHz to 6GHz, low power monolithic precision RMS power detector. The RMS detector uses a proprietary technique to accurately measure the...
Datasheet
LT5581 on Analog.com
Dear team,
Thank you.
Best & regards,
Josh
LT5581 has a DFN package for 8 lead plastic 3 x 2 mm DDB packaging. For DFN DDB 8 pin packages we clasiffy them as MSL(Mositure Sensitivity Level) 1, please refer to the below table.
…Hi,
Please find the MSL rating for the DFN package 8 lead 3 x 2 mm DDB packaging along with MSL rating for all the surface mount packages from linear in the below link:
Dushyanth.
Dushyanth.
Hello
Could I receive the PDF file for MSL?
Thank you.
Josh.
www.analog.com/.../msl-package_26apr2016.pdf
Dushyanth.
