HMC8500 : strong compression of positive half-wave
Product Number: HMC8500
I am testing the HMC8500 AD eval board with CW sinewave at 330 MHz, Vdd = 28V, Vgg = -2.3V, Iddq = 100mA, load = 50Ohm :
- -4dBm / input -> 15.5dBm / output : slight compression of positive half wave
- 2dBm / input -> 21dBm / output : significant compression of positive half wave
- 7dBm / input -> app. 25dBm / output : very strong compression of positive half wave
I was expecting a nice sinewave output - especially at these low power levels.
Where is my misunderstanding of this device ?
I.e., can I not achieve symmetric output voltages at Pout >> 20 dBm ?
  • Hi Benlumentum,
                                  HMC8500 is fabricated using Gallium Nitride, (GaN). GaN devices exhibit a soft compression characteristic. So, the gain rolls off earlier than GaAs devices do. Refer to Figures 29 thru 33 in the HMC8500PM5E datasheet. This soft gain compression is shown.
    Jim B
  • Thank you, Jim, for the hints.
    But its only the positive half-wave which is heavily compressed. The negative follows the gain of the datasheet.
    Example below : @330 MHz,  7dBm / input -> app. 25dBm / output
    - Positive half-wave = 4.8Vp
    - Negative half-wave = 6.3Vp
    At low power levels, all looks fine.
    But if I go to higher power levels, this asymmetry gets worse and worse.
    Picture below  is 2V / DIV & 1ns / DIV. Scope BW = 1.3 GHz
      Vdd = 28V, Vgg = -2.3V, load = 50Ohm
      Iddq = 100mA (RF off)
      Idd = 120 mA (RF ON)
    Marco
  • Hi Marco,
                     It is caused by the device starting to compress. The asymmetry is just how this device behaves.
    Jim B
