Hi All
Given that you plan to obsolete the HMC832 family of synthesizers in the future, which parts would you recommend as replacements?
kind regard
HMC832
Last Time Buy
The HMC832LP6GE is a 3.3 V, high performance, wide-band, Fractional-N Phase-Locked-Loop (PLL) that features an integrated Voltage Controlled Oscillator...
Datasheet
HMC832 on Analog.com
Hi All
kind regard
Hi David,
That basically depends on the requirement that is most critical for your application.
ADF4356, ADF4372 and MAX2871 are the main alternative parts.
Kazim
Thank you
Thank you
