KCC's Quizzes AQQ306 about a fish stick challenge
1. First the quote of the month: " I am so clever that sometimes I don't understand a single word of what I am saying" - Oscar Wilde
2. New quiz AQQ306 about a fish stick challenge:
Here below is a pseudo fish diagram swimming to the right.
Question
Strong EMC design
ADL5380
Recommended for New Designs
The ADL5380 is a broadband quadrature I-Q demodulator that covers an RF/IF input frequency range from 400 MHz to 6 GHz. With a NF = 10.9 dB, IP1dB = 11...
Datasheet
ADL5380 on Analog.com
ADL5308
The ADL5308 is a logarithmic transimpedance amplifier optimized
for wide dynamic range signal level monitoring in fiber optic systems.
It produces an accurate...
Datasheet
ADL5308 on Analog.com
Hi Aishwarya,
Here's some commentary regarding your questions:
Best Regards,
David
Hi David,
Thank you for the response. I have one more confusion. Could you please explain how theoretically, the differential 50 ohm at the output of I/Q demodulator is being transferred as 50 ohm single ended input to spectrum/network analyzer? Is it 50ohm parallel to 450 ohm?
Hi regarding the gain;
When we connect the single ended output to spectrum analyzer, what are we supposed to see in terms of power level? Suppose if I provide, -20dbm of RF Power, could you please explain why am I seeing -29dBm of power at QP/IP pin of EVAL board?
Hi Aishwarya,
Best Regards,
David
Hi Thanks for the clarification. Could you please let me know where can i get IMT Table and S-Parameter file for ADL5380?
Hi Aishwarya,
You're welcome. Unfortunately, at this time there's not an IMT table or S2P files readily available for the ADL5380. The best I can offer is the data that is published in the datasheet. You will note that the return loss is respectable; please see the typical plots.
Best Regards,
David
