It's stated in the datasheet that detectors work from 10 MHz.
Does it applicable to use to work with from 1 MHz?
LT5581
Production
The LT5581 is a 10MHz to 6GHz, low power monolithic precision RMS power detector. The RMS detector uses a proprietary technique to accurately measure the...
Datasheet
LT5581 on Analog.com
Hi YuriyL,
With larger external capacitors, operation may be possible, but the internal 150 kHz filter (ref. block diagram on datasheet page 9) may not give enough attenuation of the RF carrier ripple.
Hi YuriyL,
