Strong EMC design
ADL5580
Recommended for New Designs
The ADL5580 is a high performance, single-ended or differential amplifier with 10 dB of voltage gain, optimized for applications spanning from dc to 10...
Datasheet
ADL5580 on Analog.com
Hello
I have a question about the gain of the ADL5580.
The Voltage Gain item of P3 in the data sheet says 10dB for both differential and single end.
However, if you check Figures 6 to 8 on P10, the gain is about 13dB.
Under what conditions are Figures 6 to 8 measured?
We believe that 10 dB is correct as shown in Figure 9.
I would appreciate it if you could reply.
Best Regards,
Knj
Hi Knj,
The specs table might confuse you. Gains are defined as the voltage gain there, but the gain plots in Figures 6 and 9 are power gain.
Figure 6 is the power gain for differential input/output mode so 10log(100/50) =3dB is added to around 10dB voltage gain.
3dB losses are observed in Figure 9 because the input and output are 50ohm.
Hi Nao,
thank you for your quick response.
This time, I would like to use the differential at 10dB.
Looking at the data sheet, there is a description that the gain can be adjusted with an external resistor.
Could you tell me the recommended configuration and constants when using at 10dB?
The input voltage amplitude is 600mVp-p and we plan to input up to about 3GHz.
Best Regards,
Knj
Hi Knj,
if you want to have 10dB power gain, please insert series 25ohms resistors in each output before 50ohms load. it allows you to have 100ohm load and its power (=Voltage) gain becomes 10dB. you can also run S-parameter simulations to confirm.
Nao
Hi Nao,
Thank you for your reply.
I understand the configuration for 10dB.
Since there is a possibility of adjusting the gain in the future, could you tell me the formula for determining the resistance?
Best Regards,
Knj
I would appreciate it if you could reply to this matter.
Best Regards,
Knj
Hi Knj,
I am sorry for my late.
I reviewed the concept of gain adjustment one more time.
In your case, let's focus on the voltage gain because you know what output signal levels in Vpp are.
To decrease the voltage gain, please insert the resistor (Rp) parallelly as the output load.
so voltage gain is derived as 20*LOG10( (2*Rp)/(50+2*Rp) ) +10dB.
If you insert 50ohms (Rp), the voltage gain becomes 6.5dB.
The power gain is dependent on the road impedance/resistor. It confused me to consider on the gain. You can also simulate this at S-parameter data.
if you insert a series resistor, the voltage gain increases but the power gains decrease a little bit.
Thanks
Hi Nao,
I have only one question.
Regarding the formula you taught me, is it correct to use resistors in parallel rather than in series?
I thought that a resistor was inserted in series with such an image.
Isn't the denominator not 50+2*Rp in parallel? I think.
Best Regards,
Knj
Hi Knj
Yes, the parallel resistor can decrease the voltage gain. Attached 2 images below. One is an ideal road impedance at 50ohms so you can see 10dB voltage gain and 13dB power gain. the second one is terminated at 25ohms which is inserted with a parallel 50ohms resistor. It shows 6.67dB voltage gain. ADISimRF is a quick tool which allows us to confirm the rf signal chains. for the resistor load, we need to use same numbers for Zin and Zout.
when 100ohms load is used, the voltage gain increases to 12.7dB.
Nao
