Dear Sir
Please can you recommend a loop filter operational amplifier for ADF4108 PLL chip and HMC586 VCO? Which operational amplifier is best suited for the loop filter?
Thanks
ADF4108
Recommended for New Designs
The ADF4108 frequency synthesizer can be used to implement local oscillators in the up-conversion and down-conversion sections of wireless receivers and...
Datasheet
ADF4108 on Analog.com
HMC586
The HMC586LC4B is a wideband GaAs InGaP Voltage Controlled Oscillator which incorporates the resonator, negative resistance device, and varactor diode...
Datasheet
HMC586 on Analog.com
Dear Sir
Thanks
This will depend on the performance and the loop bandwidth you are targeting.
Please see here:
FAQ: OP-AMP choice for active PLL loop filters
and here:
ADA4625 is a good high performance option or OP184/ADA4084 are acceptable cheaper options for narrower loop bandwidths.
Alex
Please see here:
and here:
Alex
