HMC439 use as frequency Comaprison
The user wants to compare two frequencies using the HMC439 and a loop filter without a VCO. The support engineer suggests this is not the intended use and may introduce hysteresis, recommending a mixer or the AD8302 for frequency comparison. The AD8302 can measure phase difference, but the user needs to convert frequency difference to phase difference for accurate measurement.
Product Number: hmc439
Hi, I want to use HMC439 and Loop Filter to compare two frequencies. I do not want to use VCO.
The idea is to input two different frequencies to HMC439 then use a loop filter and read the output voltage of loop filter to draw the comparison between the input frequencies.
Can i do it using HMC439 because in doing so, i will not be using VCO and hence loop is not closed.
