I am a research student at National university of sciences and technology. I am in my thesis phase and working on power amplifiers. Can you please provide the non linear model for "HMC465LP5 / 465LP5E".
HMC465LP5
Production
The HMC465LP5(E) is a GaAs MMIC PHEMT Distributed
Driver Amplifier packaged in leadless 5x5
mm surface mount package which operate between
DC and 20 GHz...
HMC465LP5 on Analog.com
Hi Mina,
The linearity of the amplifier is dependent on frequency can be extrapolated from the typical OP1dB and Psat data given in the data sheet. You can relate this to the input via:
OP1dB (dBm) = IP1dB (dBm) + Small Signal Gain (dB) - 1 dB
Additional graphs in the data sheet give you an idea of how linear the HMC465LP5 is over temperature. Here is the datasheet for your reference:
https://www.analog.com/media/en/technical-documentation/data-sheets/hmc465.pdf
Best,
Wes
