What is the best way to terminate the VDET and VREF pins if the detector circuit is not being used?
Is it OK to connect these pins to ground? Or must they be left open, not-connected?
Thank you.
HMC943APM5E
Production
The HMC943APM5E is a four stage, gallium arsenide (GaAs), pseudomorphic high electron mobility transistor (pHEMT), monolithic microwave integrated circuit...
Datasheet
HMC943APM5E on Analog.com
Thank you.
Hi GeoffatCPI,
A good amount of our customers leave these pins open and this has not posed a problem. This is the most common configuration if these pins are going to be unused.
DanO
Thanks, Dan.
