ADF4371 PLL device will not lock when frequency applied at PFD is greater than 125MHz. Specification indicates it should operate at up to 250MHz at the Phase Frequency Detector. I am making this observation while using the EV-ADF4371SD2Z Eval Board.
Hi Leonard,
I found the root cause of the problem.
We are giving frequency update sequence in datasheet page 23. According to this, if PFD frequency is higher than 125 MHz, we are suggesting to use half…
Hi Leonard,
That is the ACE version. You can update the installed plug-ins through Plug-in Manager --> Available Updates.
The latest plug-in versions are 1.2022.3300 as given below.
Kudre…
Hi Kudret,
Are you referring to version 1.26.3240? My installation just got flagged to download the latest which is 1.26.3240.
Thanks
Leonard
Hi Leonard,
Kudret
Hi Leonard,
Kudret
