hy,
in the data sheet of the ADF4360-0 frefin minimum is mentioned with 10MHz with an advice to couple below 10MHz via DC. I try to use 2MHz TTL-Signal to frefin with the result of large jitter on the R-Out monitored on MUXOut and no lock of the PLL.
Is it possible to use 2MHz as 3,3V TTL-Signal to frefin?
thanks for hints.
best regards
Eck
