KCC Quizzes AQQ303 about the radius of a circle
1. Quote of the month: "When I die, I want to die like my grandfather who died peacefully in his sleep. Not screaming like all the passengers in his car" - Will Rogers
2. Quiz AQQ304 about finding the radius of a circle
Good luck, and try to be
August Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Important: Read the blog first . The quiz questions are all based on the content of the blog:
Stay in the loop and win! Read the blog Current Output Driving Industrial Loops , then take our quick five-question quiz for a chance to win a gift card
HMC3653
Recommended for New Designs
The HMC3653LP 3BE is a HBT Gain Block MMI C
amplifier covering 7 GHz to 15 GHz and packaged
in a 3x3 mm plastic QFN SM T package. This versatile
amplifier...
Datasheet
HMC3653 on Analog.com
HMC3563 has Reverse Isolation graph on page 4 in the datasheet. But there is no Reverse Isolation graph when power is off. Do you have such measurements? If yes I would appreciate it if you could provide the data.
Ivan
Hi Ivan,
The measurement you request has not been taken. I'm assuming you mean dc power, not RF power correct? It's not something that would be normally considered as part of normal operation of the amplifier.
Jim B
Hi Jim,
Sorry for this confusion. I meant S21 graph at Vcc=5 V, Vpd=0 V. Do you have such measurements?
Ivan
Hi Ivan,
The condition with VPD = 0 and VCC = 5V was not measured. I do have data with VPD varied from 4.5 V to 5.5 V.
I have attached that data.
When VPD = 0V, ICC = ~4mA, so the Part is turned off an essentially there is no gain.
Jim B
Hi Jim, Thank you!
Is there any chance that you could measure S21 vs frequency at Vcc=5 V, Vpd=0 V?
Ivan
Hi Ivan,
I don't have a board available so, it may be a week or so to get the data.
Jim B
Hi Jim,
I'll be glad if you could measure and get the data.
Ivan
Hi Jim,
Thank you! I would like to get turn on and turn off time when toggle Vpd. Could you please provide it as well?
Ivan
Jim, Don P knows how to do this measurement. He just did it for me for another part using ADL6012 to detect the output envelope, probably still set up in the lab
Hi Ivan,
I Will have the turn on turn off time using VPD measured. Is there a particular frequency I should target for the RF?
Jim B
