ADF4159 Charge Pump Polarity Issue
When the polarity is negative, the correct single frequency point can be obtained, but the signal quality is poor; when the polarity is positive, the frequency point falls at the lowest point of the VCO.But my VCO increases in frequency as the voltage increases, so I need the charge pump polarity to be positive, what should I do?
The attached figure is the single-point spectrum and register configuration diagram when the polarity is negative
