HMC828 pin not connect to GND
Hi Analog Support team,
Part : HMC828LP6CE
I read the HMC828LP6CE components datasheet that recommends the NC pin to ground. But I check the HMC828LP6CE Evaluation Board, the NC pin is not connected GND as recommended in datasheet.
Can you help me check if the NC pin I connect to GND like the image, is there any problem?
Thanks.
Parents Reply Children
No Data
