I am using HMC520a as direct QPSK modulator. In this configuration, should I use IF1 as I channel and IF2 as Q channel or otherwise (IF2 as I and IF1 as Q)? A wrong implementation will give me a phase reversal.
HMC520A
Recommended for New Designs
The HMC520A is a compact gallium arsenide (GaAs),
monolithic microwave integrated circuit (MMIC), in-phase
quadrature (I/Q) mixer in a 24-terminal, RoHS...
Datasheet
HMC520A on Analog.com
The Applications section gives the configuration to connect the IF ports for sideband configuration. We recommend ordering an evaluation board and testing in your application as well.
Thanks
Hi ,
I check the performance on my circuit. Using IF2 as I chain and IF1 as Q chain works for QPSK modulation. If used otherwise, it gives a reversal error when demodulating the signal.
Thank you.
