Hello, I found a problem when using HMC788A .
What are the possible reasons for this??
Edit Notes
a[edited by: jerry_12345 at 2:02 AM (GMT -4) on 6 Jun 2021]
HMC788A
Recommended for New Designs
The HMC788A is a 0.01 GHz to 10 GHz, gain block, monolithic microwave integrated circuit (MMIC) amplifier using gallium arsenide (GaAs), pseudomorphic...
Datasheet
HMC788A on Analog.com
Hi Jerry,
I am not familiar with the TPS7A91 LDO but I'm curious as to why you are using the TCCH-80 as a bias inductor. Depending on how you are using the HMC788A (frequency range, at saturation, etc.) it's right up against some of that inductors limitations and it's value is off. We recommend using the 6.35μH Piconics conical choke (P/N: CC75T38K240G5).
DanO
Dan,
We're seeing the same issue and we are using a 6.7 uH conical inductors from Piconics. We see the same sort of thing. The current draw shoots up and the amp dies. It still passes a signal through it but there is no amplification.
It seems to happen at random. We currently have a system that uses 16 of these amps on 8 RF channels. We've had 4 channels blow in he last hour.
