ADF4371 output-power varies
Hello ADI team,
I am an ASIC/FPGA contractor. In the company I work for these days - ADF4371 is used.
The FPGA configures the PLL according to commands from a host.
We see differences in output levels - with no reason found.
The device used is of rev. 0x09.
Things to note:
The bit var_mod_en definition in the version 0 data-sheet is opposite to the definition in version A data-sheet.
In the above screen-shot - var_mod_en is according to REV-A data-sheet.
In the following screen-shots - var_mod_en is constant 1. We hoped it will solve the 8.000 GHz problem, but it did not.
But we see power-level degradations in other frequencies.
and another one
Register-values that are not frequency-dependent - are set by the FPGA according to the registers-map of the ACE software.
Please advise
Itsik
Parents
    on May 5, 2021 8:12 AM
    Hi Itsik,
    Can you share your schematic (at least output section of it) and register values that you are using?
    Kudret
  • PDF
    F9_reg_setting.txt
           case param_raw_counter_int is
                    when           0 =>  addr_to_spi <= X"0000";
                                         data_to_spi <= X"00"; -- This means 3-wire SPI
                    when           1 =>  addr_to_spi <= X"0001";
                    when           2 =>  addr_to_spi <= X"0003";
                    when           3 =>  addr_to_spi <= X"0004";
                    when           4 =>  addr_to_spi <= X"0005";
                    when           5 =>  addr_to_spi <= X"0006";
                    when           6 =>  addr_to_spi <= X"000C";
                    when           7 =>  addr_to_spi <= X"000D";
                    when           8 =>  addr_to_spi <= X"0010";
                                         data_to_spi <= reg0010_data ; -- X"28" for 8 GHz
                    when           9 =>  addr_to_spi <= X"0011";
    									 data_to_spi <= reg0011_data ; -- X"00" for 8 GHz
                    when          10 =>  addr_to_spi <= X"0012";
                                         data_to_spi <= X"40";
                    when          11 =>  addr_to_spi <= X"0014";
                                         data_to_spi <= reg0014_data ; -- X"00" for 8 GHz
                    when          12 =>  addr_to_spi <= X"0015";
                                         data_to_spi <= reg0015_data ; -- X"00" for 8 GHz
                    when          13 =>  addr_to_spi <= X"0016";
                                         data_to_spi <= reg0016_data ; -- X"00" for 8 GHz
                    when          14 =>  addr_to_spi <= X"0017";
                                         data_to_spi <= reg0017_data ; -- X"00" for 8 GHz
                    when          15 =>  addr_to_spi <= X"0018";
                                         data_to_spi <= reg0018_data ; -- X"00" for 8 GHz
                    when          16 =>  addr_to_spi <= X"0019";
                                         data_to_spi <= reg0019_data ; -- X"01" for 8 GHz
                    when          17 =>  addr_to_spi <= X"001A";
                                         data_to_spi <= reg001A_data ; -- X"00" for 8 GHz
                    when          18 =>  addr_to_spi <= X"001B";
                    when          19 =>  addr_to_spi <= X"001C";
                    when          20 =>  addr_to_spi <= X"001D";
                    when          21 =>  addr_to_spi <= X"001E";
                                         data_to_spi <= X"48";
                    when          22 =>  addr_to_spi <= X"001F";
                                         data_to_spi <= reg001F_data ; -- X"01" for 8 GHz
                    when          23 =>  addr_to_spi <= X"0020";
                                         data_to_spi <= X"14";
                    when          24 =>  addr_to_spi <= X"0021";
                    when          25 =>  addr_to_spi <= X"0022";
                                         -- data_to_spi <= X"10";   -- This value fits 250 MHz
                                         -- data_to_spi <= X"20";   -- -- This value fits the GHz range
                                         data_to_spi <= reg0022_data ; -- X"00" for 8GHz
                    when          26 =>  addr_to_spi <= X"0023";
                                         data_to_spi <= reg0023_data ; -- X"00" for 8 GHz
                    when          27 =>  addr_to_spi <= X"0024";
                                         --data_to_spi <= X"D0";   -- This value fits 250 MHz
                                         data_to_spi <= X"80";   -- -- This value fits the GHz range
                    when          28 =>  addr_to_spi <= X"0025";
                                         --data_to_spi <= X"07";
                                         data_to_spi <= reg0025_data ; -- X"0A" for 8 GHz -- RF_EN reg - various values.
                    when          29 =>  addr_to_spi <= X"0026";
                                         data_to_spi <= reg0026_data ; -- This is BLEED_ICP -- X"28" for 8 GHz
                    when          30 =>  addr_to_spi <= X"0027";
                                         data_to_spi <= reg0027_data ; -- X"C5" for 8 GHz
                    when          31 =>  addr_to_spi <= X"0028";
                                         data_to_spi <= X"83";
                    when          32 =>  addr_to_spi <= X"002A";
                    when          33 =>  addr_to_spi <= X"002B";
                                         data_to_spi <= reg002B_data ; -- bit 0 is the bit sd_en_frac0 -- X"01" for 8 GHz
                    when          34 =>  addr_to_spi <= X"002C";
                                         data_to_spi <= X"24";
                    when          35 =>  addr_to_spi <= X"002D";
                                         data_to_spi <= reg002D_data ; -- X"09" for 8 GHz
                    when          36 =>  addr_to_spi <= X"002E";
                                         data_to_spi <= reg002E_data ; -- X"0A" for 8 GHz
                    when          37 =>  addr_to_spi <= X"002F";
                                         data_to_spi <= reg002F_data ; -- X"0A" for 8GHz
                    when          38 =>  addr_to_spi <= X"0030";
                                         --data_to_spi <= X"15";
                                         data_to_spi <= X"2A";
                    when          39 =>  addr_to_spi <= X"0031";
                                         data_to_spi <= X"02";
                    when          40 =>  addr_to_spi <= X"0032";
                                         data_to_spi <= X"04";
                    when          41 =>  addr_to_spi <= X"0033";
                    when          42 =>  addr_to_spi <= X"0034";
                                         data_to_spi <= X"8A";
                    when          43 =>  addr_to_spi <= X"0035";
                                         data_to_spi <= X"FF";
                    when          44 =>  addr_to_spi <= X"0036";
                                         data_to_spi <= X"30";
                    when          45 =>  addr_to_spi <= X"0037";
                    when          46 =>  addr_to_spi <= X"0038";
                    when          47 =>  addr_to_spi <= X"0039";
                    when          48 =>  addr_to_spi <= X"003A";
                                         data_to_spi <= X"55";
                    when          49 =>  addr_to_spi <= X"003D";
                    when          50 =>  addr_to_spi <= X"003E";
                                         data_to_spi <= X"0C";
                    when          51 =>  addr_to_spi <= X"003F";
                    when          52 =>  addr_to_spi <= X"0040";
                                         data_to_spi <= X"50";
                    when          53 =>  addr_to_spi <= X"0041";
                                         data_to_spi <= X"28";
                    when          54 =>  addr_to_spi <= X"0042";
                    when          55 =>  addr_to_spi <= X"0043";
                    when          56 =>  addr_to_spi <= X"0044";
                    when          57 =>  addr_to_spi <= X"0045";
                    when          58 =>  addr_to_spi <= X"0046";
                    when          59 =>  addr_to_spi <= X"0047";
                                         data_to_spi <= X"C0";
                    when          60 =>  addr_to_spi <= X"0052";
                                         data_to_spi <= X"F4";
                    when          61 =>  addr_to_spi <= X"006C";
                    when          62 =>  addr_to_spi <= X"006E";
                    when          63 =>  addr_to_spi <= X"006F";
                    when          64 =>  addr_to_spi <= X"0070";
                                         data_to_spi <= reg0070_data ; -- X"E3" for 8 GHz
                    when          65 =>  addr_to_spi <= X"0071";
                                         data_to_spi <= reg0071_data ; -- -- X"E3" for 8 GHz
                    when          66 =>  addr_to_spi <= X"0072";
                                         data_to_spi <= X"32";
                    when          67 =>  addr_to_spi <= X"0073";
                    when          68 =>  addr_to_spi <= X"0079";
                    when          69 =>  addr_to_spi <= X"007A";
                    when          70 =>  addr_to_spi <= X"007B";
                    when          71 =>  addr_to_spi <= X"007C";
                when others =>
                                        addr_to_spi <= ( others => '0' ) ;
                                        data_to_spi <= ( others => '0' ) ;
                                        assert ( false )
                                        report "File: F9_CONTROL: reached the 'OTHERS' entry in a case -line 1646"
                                        severity failure ;
           end case ;
    Hello Kudret,
    Attached is the schematic of the board - the PLL that we are facing problems with.
    There are several ADF4371 and ADF4372 devices on the board. Board schematics is almost the same - depends on output frequency used.
    Most of the PLLs are configured to a fixed setting - we use the register setting from the ACE software - with the modifications of board-voltage-dependent registers. They work Fine.
    For the F9 PLL - our on-board FPGA configures the F9 PLL according to frequency setting from a host.
    The attached .txt file contains part of the VHDL file that configures this PLL.
    This part is a case block - that chooses address and data to the PLL according to the index.
    For most registers - the content written is fixed, fore some - our block generates the required values.
    The index param_raw_counter_int starts at 71 and decreases to 0. Thus reg0010  is written after all required registers
    have already been written.
    The same mechanism is used for all other PLL devices.
    Itsik
    on May 11, 2021 6:28 AM in reply to Itsik
    Thanks for the schematic and register settings. I am reviewing it.
    Did you try to use another AC coupling capacitor at the output instead of 1.7 pF? Can you try to use a 10 pF RF capacitor?
    Kudret
  • Hello Kudret,
    Here is what the analog-engineer here wrote me a few minutes ago:
    "I Just Checked the solution advised by  Kudret from Analog Device.
    Replaced The 1.7Pf capacitor with 10Pf capacitor as offered.
    The problem remain the same. No change."
    Itsik
    on Jul 12, 2021 1:18 PM in reply to Itsik
    Hi Itsik,
    Sorry for not following up your query. Are you still having issues or resolve it?
    Kudret
  • Hello Kudret,
    In this project I am responsible for the digital part of the board.
    I asked the engineer that is responsible for the analog part.
    He says that the problem still exists.
    Itsik
  • +1
    on Aug 9, 2021 3:40 PM in reply to Itsik
    Hello Itsik,
    var_mode_en bit should not affect the output power. In the screenshots in your first post, the frequency of low output are different. Are these measurement from the same board with only changing the var_mode_en setting? Is there any other difference?
    I noticed that the pull-up inductor on the RF8 output are DNP. The allowed power level settings are -4dBm (b'00) and -1dBm (b'01). In your code, it is set to b'10. Is it possible to change this setting and/or insert inductors?
    If that does not solve the problem, there might be a signal integrity problem. Is there any other part from the ADF4371 output to the spectrum analyzer? Is that the direct connection?
    Kazim
Reply
  • +1
    Hello Itsik,
    Kazim
Children
  • Hello Kazim,
    In the time that elapsed from my initial application to ADI regarding this issue - we have already shipped
    our products to our customer. So far - our customer is satisfied - products are working OK at customer
    premises. Therefore we currently do not have plans for additional R&D activity in this project.
    We will keep your feedback - and use it in case there will be a requirement from our customer to
    investigate this issue.
    Itsik
