Is there a device in either the ADI or LTC product lines that is similar in specifications to the LTC5530 but has a lower frequency range?
Something in the 100 KHz. to 1 GHz. range would be nice.
Thank you.
Lawrence Goga
LTC5530
Production
The LTC5530 is an RF power detector for RF applications operating in the 300MHz to 7GHz range. A temperature compensated Schottky diode peak detector and...
Datasheet
LTC5530 on Analog.com
Thank you.
Lawrence Goga
Hi Lawrence, look at LTC5507. This device uses external RF coupling and peak hold capacitors, so the low frequency limit is arbitrary.
-Bruce H.
