ADAR1000 50ohm termination
Hi. I want to use adar1000 to implement phased array antenna.
When using only the Tx port of the chip, should I connect a 50 ohm resistor to the Rx ports to make a 50 ohm termination?
Or is it possible to open the chip pad because it is internally terminated at 50 ohms?
According to the datasheet, it doesn't seem to be a 50-ohm termination inside the chip.
"According to the datasheet, it doesn't seem to be a 50-ohm termination inside the chip." is added.
[edited by: juuuuuik at 6:30 AM (GMT -4) on 19 Apr 2021]
