ADF5610 - Wenzel 100MHz ref specs
What is the phase noise spec for Wenzel 100MHz source?
Can you share the part number?
Possible to reproduce in simulation (SimPLL) if the REF is making a difference in phase noise?
  • +1
    on Apr 20, 2021 8:02 PM
    Attached is a file containing information on the Wenzel reference oscillator.
    Part number: 501-19250
    You can model this in SimPLL by using the reference library editor.
    When the reference library editor window opens, select : New
    Then  select Table for Phase Noise as below.
    From there you can enter the values for phase noise at different frequency offsets as in the datasheet.
    Kieran
    PDF
