LT5560 how to connect the LO input for upconvert or downconvert
Hi all,
Our Customer will design the mixer circuits with LT5560.
Please advice to us.
1. When using with a single-ended LO drive, how to connect the LO input (LO+, LO-) for upconvert or downconvert ?
Is it okay to connect to either LO+ or LO- ?
Does swapping LO+ and LO- change the characteristics?
Or is there a recommended circuit configuration and connection method?
2. When using with a differential LO drive, is there a recommended circuit configuration and connection method?
sss
Parents
  • +1
    on Apr 8, 2021 9:49 AM
    I am not familiar with this part, but pages 12 - 14 of the datasheet have several test circuits showing either the LO+ or LO- input being used in single-ended mode. The unused input is terminated with a cap to ground.
    I assume you can use whichever input suits you best (e.g. best trace routing on your board).
    Page 17 of the datasheet has more info on the LO input, along with a simplified schematic.
Reply
  • +1
Children
No Data
