ADF5610 EVB Ref Freq
Could anyone clarify and give me any advice?
Part : ADF5610
1. ADF5610 EVB Direct External Ref Freq connect
Using the ADF5610 EVB, I want to use Ref Freq=200MHz.
The ADF5610 EVB has HMC1031, so I know it is difficult to use.
So, External Ref Freq. I want to use it directly.
Is it the right way?
2. RF OUT at 12GHz
There is a VCO Register in the VCO Subsystem tap in ADF5610 EVB Software.
It is shown saturated at 12 GHz.
This is a PLL operating up to 14.6G.
Please tell me the right way to drive it.
Please kindly help.
Please. Can someone tell me?
Thanks in advance.
Top Replies
  • +1
    on Mar 22, 2021 10:07 AM
    To address your questions:
    By default the eval board is set up for on-board reference. To reconfigure for external reference source, there are a number of discrete components to be removed/inserted. As documented in the eval board user guide (page 5):
    • Include 0 Ohms: R51, R47.
    • Remove: R33, C85, R100, R99, C50, C51, R52, C53.
    • Replace: L3 and C36 with a 0 Ω resistor.
    • Set switch D0
    When you say saturated, which value are you referring to? None of the values highlighted determine the frequency of operation. Auto-calibration is used to selected the operating frequency initially. This selects the VCO core and sub-band. This is outlined on p19 of the datasheet
