Hello everyone,
I have a AD9851 and try to make different sin-waves with frequencies around 0 to 15 MHz. Here are my Schematics:
I connected it to a teensy 2.6 Microcontroller and programmed it with arduino ide. I run it in serial mode and with the 6xREFCLK-function. Here my Code:
/*************************** VARIABLE DECLARATION ***************************/ // ADC init variabl int ADC_RESOLUTION = 13; // AD9851 Pins int wclk = A8; int fqud = A7; int DATA = A9; unsigned long freq = 0; unsigned long DDSLong; unsigned long Bitmask32 = 1; float twoE32 =pow (2,32); float clock_frequency = 180000000; int LED = 24; /*************************** SETUP ***************************/ void setup() { // put your setup code here, to run once: pinMode(wclk, OUTPUT); pinMode(fqud, OUTPUT); pinMode(DATA, OUTPUT); // AD9851 enter serial mode digitalWrite(wclk, HIGH); digitalWrite(wclk, LOW); digitalWrite(fqud, HIGH); digitalWrite(fqud, LOW); pinMode(AD8302_MAG, INPUT); pinMode(AD8302_PHASE, INPUT); pinMode(LED, OUTPUT); digitalWrite(LED, HIGH); // Teensy 3.6 set adc resolution analogReadResolution(ADC_RESOLUTION); Serial.begin(9600); } void loop() { // put your main code here, to run repeatedly: for(freq = 0; freq <= 15000000; freq += 100000) { //freq = 2; // Frequenz in Kilohertz DDSLong = (unsigned long)((twoE32 * (freq))/ clock_frequency); for (int i = 0; i <= 31; i++) { if(DDSLong & ((unsigned long)1<<i)) { digitalWrite(DATA,LOW); } else { digitalWrite(DATA,LOW); } digitalWrite(wclk,HIGH); digitalWrite(wclk,LOW); } for (int i = 0; i <= 7; i++) { if ( i == 0) { digitalWrite(DATA,HIGH); } else { digitalWrite(DATA,LOW); } digitalWrite(wclk,HIGH); digitalWrite(wclk,LOW); } digitalWrite(fqud,HIGH); digitalWrite(fqud,LOW); ...
hope you can help me. Thanks!
