HMC767
Last Time Buy
The HMC767LP6CE is a fully functioned Fractional-N Phase-Locked-Loop (PLL) Frequency Synthesizer with an integrated Voltage Controlled Oscillator (VCO...
Datasheet
HMC767 on Analog.com
im using Hmc767 eval kit. i have swept a bandwidth of 150Mhz using two way sweep auto ramp mode, i want to measure the sweep time. how can i measure the sweep time. i am programing for various sweep time so i want to verify whats the sweep time im actually getting, can i see the ramp signal on the oscillocope.
While sweeping you can look at vtune on an oscilloscope and this will show a reasonable approximation of your ramp profile, especially if it's just time domain/ramp timing you are interested in.
Or you could connect the RF output to a spectrum analyser with a transient analysis feature with enough measurement bandwidth
Alex
