- Duty cycle and
- Absolute maximum for PA ON time.
above two values are not mentioned in the datasheet.
Kindly provide same.
September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
HMC1087F10
Production
The HMC1087F10 is an 8W Gallium Nitride (GaN)
MMI C Power Amplifier which operates between 2 and
20 GHz, and is provided in a 10-lead flange mount
package...
Datasheet
HMC1087F10 on Analog.com
I have moved your query about HMC1087 to RF and Microwave community.
Someone here should be able to assist you.
Thanks!
Hi vgoyal_hrd,
1) Typical duty cycle is 100us for this part.
2) I do not believe we have a CW AMR number for this part if that’s what you’re asking.
Dan
(1) Duty cycle is a ratio of two values (i.e. "time"). Duty cycle is a unit-less value. Formula for same is = PA_ON_Time/(PA_ON_Time + PA_OFF_Time). Multiply this ratio with 100 and we get values in %.
(2) Absolute maximum of PA_ON_Time, in microSecond will ensure PA-burn-free operation if I follow point(1) above as well.
