ADF5901 output power issue.
The user wants to control the output power of TXOUT 1 and TXOUT 2 on the ADF5901 with ADF4159 to 5dBm and 8dBm, respectively. The final answer explains that the Tx power can be adjusted by changing the Tx Amp Cal bitfield in register 1, but both Txs use the same amplitude setting, requiring recalibration when switching between outputs. The datasheet provides details on recalibration on pages 23 and 24.
I'm using ADF5901 with ADF4159.
i want to use txout 1 for 5dBm, txout 2 for 8dBm.
how can i control each output power ?
    The Tx power can be controlled by changing the amplitude calibration bitfield (Tx Amp Cal) in register 1 during calibration. See figure 7 in datasheet. To get different output powers on each Tx unfortunately you will have to re-run calibration with the new Tx Amp Cal code when you switch Tx to recalibrate the power, since both Txs use the same amplitude setting bitfield. The datasheet explains how to re-run calibration on page 23 & 24
    Alex
