Respected Sir,
- I am a student undergoing research MS Thesis at NUST, Pakistan I am exploring amplitude and phase steering vectors for phased array systems.
- I went through your video, and I have found out that I can utilize the evaluation boards for my research. Can you please answer my following question?
- Max Number of eval boards that can be cascaded, I saw two in your video 16 elements with two boards (8 Tx + 8 RX elements is supposed). Is it possible to make a bigger array, 16-64 element using eval boards?
- Is it mandatory to use the ADTR1107? We have a far filed anechoic chamber at university where the max distance between TX and RX antennas will be 10 m, I have seen in your video you have not used the ADTR1107. What do you recommend?
- Can you kindly provide a sample free of charge for evaluation before I place my original order?
- Can you kindly provide hardware at concession rates being a student?
- Can the hardware be procured from your distributor in China owing to lesser shipment charges and time?
- Can you provide the BOM for the setup demonstrated in the video (link below), so that I may not miss any stuff required to make MY setup running?
- Is it possible to talk to your design engineers via zoom for technical discussion?
- I will be great full for your support and assistance.
Video Link: www.youtube.com/watch
Regards
