Hi.
I am looking for a board that can down convert 24GHz - 24.25GHz.
I have found the device, ADMV1014, and its evaluation board, ADMV1014-EVALZ.
However, the evaluation board supports downconversion from 24.5GHz instead of 24GHz.
I would like to know if there is any way to use 24GHz on the ADMV1014-EVALZ.
Reading through your datasheet, I have a theory that this may be due to the quadrupler limitations.
If this is true, if I disable the quadrupler and feed 21GHz signal directly to the LO, will it be able to down-convert 24GHz?
Thank you for your time.
You can contact me by napoleon2259@gmail.com or bkm2259@kaist.ac.kr .
Sincerely,
Kangmin Bae
Masters Candidate, KAIST, South Korea.
+82 10 3130 2259, bkm2259@kaist.ac.kr
