Hello. Please tell me.
I’m using EVAL-ADF5610. REF=100MHz PDIVout=1565MHz.
・Attach the ADF5610 configuration file.
・Loop filter constants are described in PDF.
When started at 25 ° C, the LED on the evaluation board lights up to indicate LOCK.
However, when measured in a 50 ° C environment with the same settings, the LED is off and indicates unlock.
Is there a recommended value to solve this problem?
This issue does not occur when REF = 50MHz
Also, changing "LKD_ONESHOT_DURATION" does not improve this problem.
Best Regards.
CheckBox: MagOffsetAutosetBox.Checked = True CheckBox: WriteAllBox.Checked = True CheckBox: RepeatSweepBox.Checked = False RadioButton: ADF5610.Checked = True RadioButton: SDPBSelector.Checked = False RadioButton: SDPSSelector.Checked = True ComboBox: VTuneResBox.SelectedIndex = 7 ComboBox: AutocalDisableBox.SelectedIndex = 0 ComboBox: ForceCurveBox.SelectedIndex = 0 ComboBox: VSPITrigBox.SelectedIndex = 0 ComboBox: FSM_VSPI_SelBox.SelectedIndex = 2 ComboBox: NFETBox.SelectedIndex = 0 ComboBox: PFETBox.SelectedIndex = 0 ComboBox: LDODriverBox.SelectedIndex = 1 ComboBox: AutomuxBox.SelectedIndex = 0 ComboBox: GPOTestDataBox.SelectedIndex = 0 ComboBox: GPOSelBox.SelectedIndex = 1 NumericUpDown: ChPerPFDBox.Value = 0 ComboBox: ForceCPUpBox.SelectedIndex = 0 ComboBox: ForceCPMidBox.SelectedIndex = 0 ComboBox: ForceCPDnBox.SelectedIndex = 0 ComboBox: CSPModeBox.SelectedIndex = 0 ComboBox: DivPulseWidthBox.SelectedIndex = 0 ComboBox: PDDnEnBox.SelectedIndex = 1 ComboBox: PDUpEnBox.SelectedIndex = 1 TextBox: HFRefDisplayBox.Text = Low Freq Ref ComboBox: _8GHzDiv2Box.SelectedIndex = 1 ComboBox: VCOBuffPresEnBox.SelectedIndex = 1 ComboBox: BiasEnBox.SelectedIndex = 1 ComboBox: PDEnBox.SelectedIndex = 1 ComboBox: CPEnBox.SelectedIndex = 1 ComboBox: RefBuffEnBox.SelectedIndex = 1 ComboBox: GPOPadEnBox.SelectedIndex = 1 ComboBox: VCOBuffEnBox.SelectedIndex = 1 ComboBox: AutoClkConfBox.SelectedIndex = 0 ComboBox: SDEnBox.SelectedIndex = 1 ComboBox: BypassFracBox.SelectedIndex = 0 ComboBox: SeedBox.SelectedIndex = 2 ComboBox: GPODriverOnBox.SelectedIndex = 0 ComboBox: VCOOnBox.SelectedIndex = 0 ComboBox: RefBuffOnBox.SelectedIndex = 0 ComboBox: CPOnBox.SelectedIndex = 0 ComboBox: PFDOnBox.SelectedIndex = 0 ComboBox: BiasOnBox.SelectedIndex = 0 ComboBox: ResetCP_SPIBox.SelectedIndex = 1 ComboBox: ResetCEPinBox.SelectedIndex = 0 NumericUpDown: ReadAddressBox.Value = 0 TextBox: ReadChipIDTextBox.Text = Read.val! ComboBox: OffsetDownEn.SelectedIndex = 1 ComboBox: OffsetUpEn.SelectedIndex = 0 TextBox: OffsetMagLabel.Text = 635 NumericUpDown: OffsetMagBox.Value = 127 TextBox: ChargePumpDnCurrentGainNumberLabel.Text = 404.25 TextBox: ChargePumpUpCurrentGainNumberLabel.Text = 404.25 TextBox: ChargePumpUpGainNumberLabel.Text = 2540 TextBox: ChargePumpDnGainNumberLabel.Text = 2540 NumericUpDown: ChargePumpDnGainBox.Value = 127 NumericUpDown: ChargePumpUpGainBox.Value = 127 ComboBox: LDWindCountBox.SelectedIndex = 5 ComboBox: LDModeBox.SelectedIndex = 1 ComboBox: InternalLDEnBox.SelectedIndex = 1 ComboBox: LDWindowDurBox.SelectedIndex = 1 ComboBox: OneTryRelockBox.SelectedIndex = 1 ComboBox: LDDigTimerBox.SelectedIndex = 3 RadioButton: ADF_AutomaticRadio.Checked = True RadioButton: ADF_ManualRadio.Checked = False ComboBox: ADF_UseOtherxHzBox.SelectedIndex = 4 NumericUpDown: ADF_StepSizeOtherBox.Value = 1 TextBox: DivRatioDisplayBox.Text = 8 TextBox: DivEnDisplayBox.Text = Enabled TextBox: IntFracDisplayBox.Text = Fractional-N Mode TextBox: ADF_VCOFreqTextBox.Text = 0.0 TextBox: ADF_PFDBox.Text = 100 NumericUpDown: ADF_NINTBox.Value = 31 NumericUpDown: ADF_NFRACBox.Value = 5033164 TextBox: RFOutTextBox.Text = 12520.00000000 TextBox: DivOutFreqTextBox.Text = 1565.00000000 NumericUpDown: ADF_VCOFreqBox.Value = 6260 TextBox: ADF_ActualVCOoutputBox.Text = 6259.999990463 TextBox: ADF_VCOOutputFrequencyErrorBox.Text = -0.000009537 ComboBox: HFRefBox.SelectedIndex = 0 NumericUpDown: RdividerBox.Value = 1 NumericUpDown: RefFreqBox.Value = 100 NumericUpDown: VCODataBox.Value = 380 NumericUpDown: VCORegAddrBox.Value = 1 NumericUpDown: VCOIDBox.Value = 0 ComboBox: RFDivBox.SelectedIndex = 4 ComboBox: VCOEnBox.SelectedIndex = 0 ComboBox: PDDivBox.SelectedIndex = 1 ComboBox: DivOutPBox.SelectedIndex = 3 ComboBox: VCOBiasBox.SelectedIndex = 7 ComboBox: RFOutPowerBox.SelectedIndex = 0 NumericUpDown: CapsBox.Value = 0 ComboBox: CalBox.SelectedIndex = 0 TextBox: HopFBBox.Text = 5100 TextBox: HopFABox.Text = 5000 TextBox: HopCurrent.Text = TextBox: HopDelayBox.Text = 100 TextBox: SweepCurrent.Text = TextBox: SweepDelayBox.Text = 100 TextBox: SweepSpacingBox.Text = 1 TextBox: SweepStopBox.Text = 5010 TextBox: SweepStartBox.Text = 5000 ComboBox: AutoseedBox.SelectedIndex = 1 TextBox: VCOBusyReadbackTextBox.Text = Read.value! TextBox: VCOBandTextBox.Text = Read.value! TextBox: RawReg16ValTextBox.Text = N/A TextBox: RawReg19ValTextBox.Text = N/A TextBox: BISTReadbackTextBox.Text = Read.value! TextBox: RawReg18ValTextBox.Text = N/A TextBox: GPOReadbackTextBox.Text = Read.value! TextBox: LockDetectReadBackTextBox.Text = Read.value! TextBox: RawReg17ValTextBox.Text = N/A TextBox: ErrPolReadbackTextBox.Text = Read.value! TextBox: ErrMagReadbackTextBox.Text = Read.value! NumericUpDown: GenericWriteRegSelectedRegBox.Value = 1 TextBox: GenericWriteRegHexAddrTextBox.Text = 0x1 TextBox: GenericWriteRegValToWriteTextBox.Text = 0 TextBox: GenericRegReadDecimalTextBox.Text = Read.val! NumericUpDown: GenericReadRegReadingBox.Value = 1 TextBox: GenericReadRegHexValTextBox.Text = 0x1 TextBox: GenericRegReadTextBox.Text = Read.val!
