Can we apply differential input to HMC856 directly. Will 50ohm internally terminated resistor(CML) affect our input or not?
You can apply differential input to HMC856 directly. The source should have 50ohms single ended impedance or 100ohms differential impedance. You need to have your impedance matched to the HMC856 input impedance 50ohms single ended or 100ohms differential.
Thanks Salemdar.
I have one more question to ask. Can i apply LVDS at the control inputs?
As long as the DC termination levels and swings are compatible with CML you can apply any signal. If DC bias points do not match, please use a DC block capacitor.
Best regards
Best regards
