No output from ADF4350 when programmed correctly at certain frequencies
I'm using the ADF4350 to generate the clock for the AD9914 and I would like the frequency to be either 2^31 Hz = 2147.483648 MHz or 3500 MHz which I generate from a 100 MHz reference. Using the evaluation software gives me the values I need to write to each register, shown below for the two frequencies. This works perfectly for 3500 MHz since MUXOUT - configured as  digital lock detect - goes high and the beatnote with another frequency source locked to the same reference is zero. However, when I program the ADF4350 with the configuration for 2^31 Hz, the digital lock detect never goes high. Has anyone else run into this issue before?
Thanks
  • It looks like the screenshot of the configuration for 3500 MHz wasn't included with my previous post so here it is
    You are using 20 MHz PFD frequency for 3500 MHz and 160 kHz PFD frequency for 2^31 Hz. Your loop filter may not be appropriate for 160 kHz PFD operation. If you can send your loop filter, I can check it with ADISIMPLL.
    Kudret
  • Thanks for your prompt reply. I tried your suggestion to operate them both at the same PFD frequency with the right loop filter, but now the lock is not working at either output frequency. I'm attaching a screenshot of of the two loop filters I used. The values in black are those suggested by ADIsimPLL for PFD frequency = 320 kHz, the values just below in red are the ones I am using in the new loop filter that runs at 320 kHz, and the ones in brown below those are for the first loop filter I tried where 3500 MHz was working. I am also attaching screenshots of the register data I write for both output frequencies.
