Question is: as the device is supplied through the output via a shock coil, what is the negative transient voltage that could be acceptable to the output terminal? This could occurred if the power supply is not perfectly designed regarding EMC management. Then oscillations of the shock coil could create such negative swings.
Thank you
Jean Pierre
