ADL5569 Single ended output
Trying to use the ADL5569 here with differential input and single ended output. Is it ok to do so? are there any recommendations when doing so? Is just terminating one leg to 50ohm ok?
thanks
Top Replies
  •  PPTX
    Yes, you can use one leg of the  output, but you may have reduced even order harmonic performance given the unbalanced output.   See the attached simulation.
    Darrell
