Dear team,
I am reviewing the HMC1087-DIE and HMC1087F10 for the wide band HPA design.
Can I get the RF performance data at 1GHz~2GHz?
- Gain
- Psat
-P1dB
Thank you.
Josh
HMC1087-Die
Production
The HMC1087 is an 8W Gallium Nitride (GaN) MMIC Power Amplifier which operates between 2 and 20 GHz. The amplifier typically provides 11dB of small signal...
Datasheet
HMC1087-Die on Analog.com
HMC1087F10
Production
The HMC1087F10 is an 8W Gallium Nitride (GaN)
MMI C Power Amplifier which operates between 2 and
20 GHz, and is provided in a 10-lead flange mount
package...
Datasheet
HMC1087F10 on Analog.com
Dear team,
- Gain
- Psat
-P1dB
Thank you.
Josh
Hi Josh,
I do not think part is useful below 2Ghz at all. Can you check s2p files for both of these parts and see response below 2GHz.
There is Gain dip around 1.4GHz. s2p files can be found at web
https://www.analog.com/en/products/hmc1087f10.html and https://www.analog.com/en/products/hmc1087-die.html
Let me know if this gain below 2Ghz is acceptable for you.
Regards
Ivan
