HMC713MS8E Enable Pin
Hi all, I have a question regarding the HMC713MS8E logarithmic detector. I want to use it as a power detector from 800MHz to 2000MHz.
The datasheet shows a power up timming diagram with the relationship between Vcc and the voltage on the Enable pin to ensure a proper power up.
What does this mean? What are the effects of connect the Enable pin to VCC through an resistor?
I don't intent to use the power down function of the detector, I want to keep it always enable.
Thank you and hope you are doing well in this hard times
Santiago
