Is it possible to have a single-ended RF output from ADF4360-7.
If it is possible, is it just enough to connect unused RF output pin to ground via a 50 ohm resistor or should I use a balun ?
Thanks in advance.
Thanks in advance.
You can use 50 ohm to ground for unused output. You can also use balun if you want to increase the output power.
Kudret
