FAQ: External bypass capacitors on HMC1131
Q: Is it possible to reduce the number external bypass capacitors on HMC1131?
A: You may use one 2.2 uF for all the Gate Bias Pins and one 2.2 uF for all the Drain Bias Voltage Pins. 100 pF and 1 nF per drain/gate line is still recommended.
