Use ADF4360-9 to track an incoming carrier signal around 150MHz
The user is attempting to track a 150MHz carrier signal with a frequency hopping pattern using a PFD and PLL, considering the use of a comparator (ADCMP553) to clean up the signal. The user found an alternative solution and did not require further assistance.
I am trying to track an incoming carrier signal around 150MHz for an indoor application. The carrier frequency is one of 50 random channels with a frequency hopping pattern. Most of reference designs with PFD and PLL are for clock generations with a preset frequency.  Can I use the incoming signal in place of a normal reference XO source?  There are reflections and possible other impairments to the incoming signal.  I am thinking to use a comparator such as ADCMP553 to cleanup the signal in front of the PFD. Are there any potential issues I should be aware of? Thanks.
