About the device S-parameters files
(HMC383LC4,HMC498LC4,HMC1040LP3CE,HMC1016)
To whom it may concern:
  We are going to design some PAs, using HMC383LC4,HMC498LC4,HMC1040LP3CE,HMC1016.
  These S-parameters on theirs websites are avalable.
  I want to know:
If these S-parameters are measured form theirs evaluation boards( which means the reference planes are the K connectors) or if  these S-parameters have been deembedded ( which means the reference planes are the chip pins) .
Waitting for your response and thank you very much.
B.R.
abg
  • Hi abg,
    Unless otherwise specified on the s2p filename or in the comment section at the top of the s2p file itself, s-parameters for RF amplifiers are not de-embedded, they represent the performance of the populated evaluation boards.
    Best,
    Kagan
  • Dear Kagan:
       Thank you for your fast response to my questions:
      I still have some questions in details. About the four devices(HMC383LC4,HMC498LC4,HMC1040LP3CE,HMC1016)'s S-parameters:
    1. HMC383LC4
    S-parameter file's name: "HMC383LC4 deembedded.s2p"
    Details in the comment section of this file:"Vdd = +5V, data includes two Southwest connectors, Room "
    ----So I suppposed that maybe  this S-parameter represent the performance of the populated evaluation boards. But the file name is wrong.
    2. HMC498LC4
    S-parameter file's name: "HMC498LC4_SP_EVB.s2p"
    Details in the comment section of this file:"!Misc: Vdd1,2,3 = 5 V, Idd = 250 mA, data includes two Southwest (K) connectors, Room "
    ---So I suppposed that this represent the evaluation board.
    3. HMC1040LP3CE
    S-parameter file's name: "HMC1040LP3CE_s_params.s2p"
    Details in the comment section: none of related comment
    ---Because it is packaged device, so I suppposed that this represent the evaluation board.
    4. HMC1016
    S-parameter file's name: "HMC1016_ml.s2p"
    Details in the comment section: "NO DE_EMBEDDING WAS DONE.   Data was collected using an calibrated network analyzer.  The reference plane is the microstrip launcher."
    ---This represent the evaluation board.
    Are these above-mentioned judgments  reasonable?
    Thank you very much for your help and waitting for you response again.
    Wish you have a good day!
    Thank you,
    EZ Admin
