modulator-demodulator chain LT5584 problem
Good morning to everybody,
The purpose of my project is to receive IQ data with LT5584 demodulator.
the RF modulated signal coming from LTC5598 IQ modulator (QAM16), the LO is set to 40MHz, 0dBm amplitude and it is the same for both circuits.
In IQ demodulator output, I do not understand why part of the I signalalso appers in the Q branch in a small part and vice versa.
In the example in Figure1 below, I transmitted a 4-level signal on branch I and a 0V DC on Q, as you can see when In the receiving part, I find part of the signal on branch Q
(a)  pink I signal received, blue signal I trasmitted                                        (b) pink Q signal received, blue signal I trasmitted
In this second example, I transmitted a 4-level signal on branch I and a sinus 300mVp on Q, and you can see that part of the I signal goes through Q and the other way around.
(a)  pink I signal received, blue signal Q trasmitted                                        (b) pink Q signal received, blue signal Q trasmitted
I checked the spectrum of the RF modulator and it seems ok,
Thank you in advance for your attention
