ADRF6720 Built-In-Test
I have a question about how I can perform a BIT test on the DAC to IQ modulator hardware.  I would like to verify that the DAC is outputting something to show that it is somewhat functioning.  In the past, we have commanded the output of the DAC from 0 to high and saw that the PLL would unlock.  Is there some sort of register or test I could perform that gives me confidence that the DAC is outputting something?
    on Dec 6, 2019 10:17 PM
    It sounds that you want to confirm and verify the functionality of DAC through a BIT Test tone. Some DACs have the functionality to generate a test tone as a BIT test tone. If it is the case, please post your question at the "Dataconverter-High Speed DAC" section.
    Thanks
    on Jan 13, 2020 9:30 PM
    Is there still an issue? If there is, I suggest posting a different question for a BIT test in a specific DAC you are using.  Then when there are DAC outputs in quadrature signals to drive ADRF6720 inputs in quadrature I and Q, we can move to a next step. There is no Built-In-Test functionality in ADRF6720.
    Thanks
    Tony
