ADF4360-8 single ended output
Hi
  If I do not need the differential outputs on the ADF4360-8, do I only use 50 ohm resistor to terminate the unused output? or i still need to add output matching circuit on unused output.(as Figure 28. Optimum ADF4360-8 Output Stage on datasheet).Thanks!!
