ADF4218L Power-Up Sequence
Our team is planning on using the ADF4218L on one of our products. Reading through the AskTheCommunity questions there are references on the ADF4212L about clearing all bits in the IF R Counter Latch register and RF R Counter Latch register immediately after power-up, prior to programming the desired commands. Does this same recommendation applies to the ADF4218L? And if it does is it just registers 0x0 and 0x2 that need to be cleared after power-up or do all four registers (0x0, 0x1, 0x2, x03) should be cleared after power-up prior to programming the desired commands?
ADF4212 conversations referenced above:
https://ez.analog.com/rf/f/q-a/71544/adf4212l-power-up-sequence-through-rate-2/
https://ez.analog.com/rf/f/q-a/75846/adf4212l-power-up-sequence-through-rate
