Dear sir,
Is HMC564LC4 compatible with pulsed applications ?
I mean by pulsing the drain.
If yes, what are the Raising & Falling time ?
Regards
HMC564LC4
Production
The HMC564LC4 is a high dynamic range GaAs
pHEMT MMIC Low Noise Amplifier housed in a
leadless RoHS compliant 4×4 mm SMT package.
Operating from 6 to...
Datasheet
HMC564LC4 on Analog.com
Dear sir,
Regards
Yes, This part would be compatible with pulsing the drain. You would need to design a circuit and measure the results. The by pass capacitors on the drain will affect the rise and fall times. Some experimentation might be required to get the enough by passing to maintain device stability and suitable rise and fall time.
