HMC575 input power to output power does not conform to the datasheet!
Hi there,
I am using the HMC575 evaluation board and I am trying to validate HMC575 for our design. I have a 3 Ghz signal coming in (from a signal generator) and I put that signal through a band pass filter (2.7GHz to 3.1GHz) to clean any extra spurs. I have compensated for the cable loss in my calculations, and I have connected the output of the HMC575 eval board directly to a phase noise analyzer using SMA header. but when I compare my empirical results with the datasheet, I can see that there is up to 12dBm difference in some cases with the output power measured and the power reported in the datasheet.
I can observe that a 3Ghz component is fed through from the input to the output and in some cases, the amplitude of the 3Ghz on the output is a lot more than the 6Ghz component. The following is our empirical results:
Input power (dBm), 3Ghz sine wave
HMC575 output @ 3Ghz (dBm) (Feed-through from the input on the output)
HMC575 output @ 6Ghz (dBm) (desired doubled frequency on the output)
Delta (6Ghz - 3Ghz)
-10
-4.23
-20.84
-16.61
-8
-2.26
-16.1
-13.84
-6
-0.3
-7.67
-7.37
-4
2.03
4.67
2.63
-2
4.83
11.34
6.52
0
6.24
14.99
8.75
2
5.5
16.71
11.21
4
4.86
16.91
12.02
6
5.02
15.82
10.8
8
4.62
13.8
9.18
9
4.06
12.58
8.51
Besides the 3Ghz input feedthrough, you can observe that the output power vs. input power is significantly different from what the datasheet specifies; for instance, according to the datasheet, a -8 dBm input power at 3Ghz, should result in a -4 dBm output at 6GHz. However we observe in our experiments that the 6Ghz output is -16.1 dBm!
For reference, I have included the output signal which is connected to the phase noise analyzer for an input signal at 3Ghz with -2 dBm power:
Clarified table column
[edited by: amir.b at 9:17 PM (GMT 0) on 9 Oct 2019]
Parents Reply Children
