ADF5902 Power control detector & CE function
Hi all,
Our customer will start to evaluate the EV-ADF5902SD1Z.
They have following questions.
Please advice to us.
1.Power control detector
In the datasheet,here it is.
"Each transmitter channel contains a power control circuit. There is also an on-chip temperature sensor."
We know an on-chip temperature sensor can be accessed on the ATEST pin or as a digital word on DOUT following an ADC conversion.
In the Figure 1 each TX OUT , the diode conect from each TX OUT to ADC.
We understand the diode detector can not be accessed, on-chip internal use only for setting the transmitter amplitude level and calibrating.
Is it correct ?
2.CE function
"Chip Enable. A logic low on this pin powers down the device. Taking the pin high powers up the device."
Hardware Power-Down Mode:
When CE is high to low power down, what function is power down on-chip ?
When CE is low to high power up, Initialization Sequence and Recalibration Sequence must be need ? Register setting must be re-writed ?
Software Power-Down Mode:
In the Register R0, after all functions are power-up, Initialization Sequence and Recalibration Sequence must be need ?
3.CE function @ ADF5902 GUI
Following the GUI red marking, Chip Enable is two tabs, "High/Low" and "Send".
We can not find the information for this "Send" function to use CE pin (Hardware Power-Down Mode).
What is the "Send" function ?
When is the timming to "Send" ?
"High" to "Low" and "Send" ? and "Low" to "High" and "Send" ? Each every time must be need ?
sss
Parents Reply Children
No Data
