Hi All,
I am intending to use ADRF5021 in one of our new designs. I have a 30GHz signal that will be fed to the RFC port, two loads will be connected to RF1 and RF2 and a control logic will switch between the loads.
The rise and fall time of my signal are critical for my application. So here are my questions:
- The datasheet mentions a typical trise,tfall of 1.0us. What is meant by this rise time since clearly it is not intended for a 30GHz signal ?
- No minimum rise/fall time mentioned in the datasheet. Does this mean that the switch can handle the fast rise/fall time of the RF signal (~10ps in my case) without a limitation ?
Thank you for your help,
LazyHD
