HMC1040LP3CE power on sequence
What happens to the amplifier if the power supply (Vdd) is turned on / off with a signal input to the HMC1040LP3CE?
(Die's catalog / data sheet states that the signal is turned off when the power is turned on / off.)
Is there any chance that the amplifier will be broken if the power is turned on / off with the signal input?
Question added
[edited by: yoshirou.aoki@toshiba.co.jp at 1:09 AM (GMT 0) on 15 May 2019]
